FCMP, FCMPE |
Floating-Point Compare—can set any of the four floating-point condition codes. |
LDFSR, STFSR |
Load/Store FSR- only affect low-order 32 bits of FSR |
LDUW, LDUWA |
Same as LD, LDA in SPARC-V8 |
RDASR/WRASR |
Read/Write State Registers - access additional registers |
SAVE/RESTORE |
SETHI |
SRA, SRL, SLL, Shifts |
Split into 32-bit and 64-bit versions |
Tcc |
(was Ticc) Operates with either the 32-bit integer condition codes (icc), or the 64-bit integer condition codes (xcc) |
All other arithmetic operations operate on 64-bit operands and produce 64-bit results.
