To change the keys of a nonroot server (master or replica) from the server, use these commands:
subreplica# nisaddcred des subreplica# nisupdkeys parentdir dirs |
Where:
parentdir is the non-root server's parent directory (that is, the directory containing subreplica's NIS+ server).
dirs are the directory objects you want to update (that is, the directory objects that are served by subreplica).
When running nisupdkeys be sure to update all relevant directory objects at the same time. In other words, do them all with one command. Separate updates may result in an authentication error.
Whenever you change a server's keys, you must also update the key information of all the clients in that domain, as explained in Updating Client Key Information.
