System Administration Guide: Naming and Directory Services (FNS and NIS+)
Using nischmod to Add Rights
To add rights for an object or entry use:
For object
nischmod class+right object-name
For table entry
nischmod class+right [column-name=value],table-name
For example, to add read and modify rights to the group of the sales.doc.com. directory object you would type:
client% nischmod g+rm sales.doc.com.
For example to add read and modify rights to group for the name=abe entry in the hosts.org_dir.doc.com. table you would type:
client% nischmod g+rm '[name=abe],hosts.org_dir.doc.com.'
