System Administration Guide: Naming and Directory Services (FNS and NIS+)
Removing Nondirectory Objects
To remove nondirectory objects, use the nisrm command and provide the object names:
nisrm object-name...
This example removes a group and a table from the namespace:
rootmaster% nisrm -i admins.doc.com. groups.org_dir.doc.com.
Remove admins.doc.com.? y
Remove groups.org_dir.doc.com.? y
