System Administration Guide: Naming and Directory Services (FNS and NIS+)
Forcing a Ping
If the nisping -u command reveals that a replica has not been properly updated, you can use the nisping command to force the master server to ping all the replicas in a domain, or one replica in particular.
To ping all the replicas, use the nisping command without options:
/usr/lib/nis/nisping
This forces the master server to ping all the replicas in the domain. Here is an example that pings all the replicas of the local doc.com. domain:
rootmaster# /usr/lib/nis/nisping
Pinging replicas serving directory doc.com.:
Master server is rootmaster.doc.com.
 Last update occurred at Wed Nov 25 10:53:37 1992
Replica server is rootreplica1.doc.com.
 Last update seen was Wed Nov 18 11:24:32 1992
 Pinging ... rootreplica1.doc.com.
To ping all the replicas in a domain other than the local domain, append a domain name:
/usr/lib/nis/nisping domainname
You can also ping all the tables in all the directories on a single specified host. To ping all the tables in all the directories of a particular host, us the -a option:
/usr/lib/nis/nisping -a hostname
