System Administration Guide: Naming and Directory Services (FNS and NIS+)
Listing the Contents of a Directory—Verbose
To list the contents of a directory in the verbose format, use the -l option and one or more of the options listed below. The -g and -m options modify the attributes that are displayed. If you don't supply a directory name, NIS+ will use the default directory.
nisls -l [-gm] [-dLMR] directory-name
or
Here is an example, entered from the master server of the root domain doc.com.:
rootmaster% nisls -l
doc.com.
D r---rmcdr---r--- rootmaster.doc.com. date org_dir
D r---rmcdr---r--- rootmaster.doc.com. date groups_dir
