System Administration Guide: Naming and Directory Services (FNS and NIS+)
Removing Single Table Entries
To remove a single entry from a table, use the -r option:
nistbladm -r indexed-name
This example removes the Manf-1 entry from the depts table:
rootmaster% nistbladm -r [Dept=Manf-1,Site=Emeryville,Name=hosteen],\
depts.doc.com.
You can specify as few column values as you wish. If NIS+ finds duplicates, it does not remove any entry and returns an error message instead. Thus, you could have removed the Manf-1 by specifying only the Site column value, as in this example:
rootmaster% nistbladm -r [Site=Emeryville],depts.doc.com.
However, you could not have removed the Sales entry by specifying only the Site column value (SanFran), because two entries have that same value (R&D and Sales):
Dept
Site
Name
R&D
SanFran
kuznetsov
Sales
SanFran
jhill
Manf-1
Emeryville
hosteen
Manf-2
Sausalito
lincoln
