To display the contents of a table, use:
niscat [-hM] tablename |
To display the object properties of a table, use:
niscat -o tablename niscat -o entry |
Option |
Description |
-h |
Header. Displays a header line above the table entries, listing the name of each column. |
-M |
Master. Displays only the entries of the table stored on the Master server. This ensures you get the most up-to-date information and should be used only for debugging. |
-o |
Object. Displays object information about the table, such as column names, properties, and servers. |
