System Administration Guide: Naming and Directory Services (FNS and NIS+)
Cannot Obtain Initial Context
Symptom:
You get the message Cannot obtain initial context.
Possible Cause:
This is caused by an installation problem.
Diagnosis:
Check that FNS has been installed properly by looking for the file, /usr/lib/fn/fn_ctx_initial.so.
Solution:
Install the fn_ctx_initial.so library.
