A user cannot have the same login ID as a machine name. When a machine is given the same name as a user (or vice versa), the first principal can no longer perform operations requiring secure permissions because the second principal's key has overwritten the first principal's key in the cred table. In addition, the second principal now has whatever permissions were granted to the first principal.
For example, suppose a user with the login name of saladin is granted namespace read-only permissions. Then a machine named saladin is added to the domain. The user saladin will no longer be able to perform any namespace operations requiring any sort of permission, and the root user of the machine saladin will only have read-only permission in the namespace.
Symptoms:
The user or machine gets “permission denied” type error messages.
Either the user or root for that machine cannot successfully run keylogin.
Security exception on LOCAL system. UNABLE TO MAKE REQUEST. error message.
If the first principal did not have read access, the second principal might not be able to view otherwise visible objects.
When running nisclient or nisaddcred, if the message Changing Key is displayed rather than Adding Key, there is a duplicate user or host name already in existence in that domain.
Diagnosis:
Run nismatch to find the host and user in the hosts and passwd tables to see if there are identical host names and user names in the respective tables:
nismatch username passwd.org_dir |
Then run nismatch on the domain's cred table to see what type of credentials are provided for the duplicate host or user name. If there are both LOCAL and DES credentials, the cred table entry is for the user; if there is only a DES credential, the entry is for the machine.
Solution:
Change the machine name. (It is better to change the machine name than
to change the user name.) Then delete the machine's entry from the cred table and use nisclient
to reinitialize the machine as an NIS+ client. (If you wish, you can use nistbladm to create an alias for the machine's old name in the hosts
tables.) If necessary, replace the user's credentials in the cred table.
