NIS_PATH
Make sure that your NIS_PATH
variable is set to something clean and simple. For example, the default: org_dir.$:$. A complex NIS_PATH, particularly one that itself contains a variable, will slow
your system and may cause some operations to fail. (See NIS_PATH Environment Variablefor
more information.)
Do not use nistbladm to set nondefault table paths. Nondefault table paths will slow performance.
