System Administration Guide: Naming and Directory Services (FNS and NIS+)
niscat Returns: Server busy. Try Again
Symptoms:
You run niscat and get an error message indicating that the server is busy.
Possible Cause:
Diagnosis:
Run swap -s to check your server's swap space.
Solution:
You must have adequate swap and disk space to run NIS+. If necessary, increase your space.
