Symptom:
When you run fndestroy on the host or user context the context is not removed.
Possible Cause:
You do not own the host or user context. When you create a user or host context it is owned by the host or user, and not by the administrator who set up the namespace.
Diagnosis:
Check the NIS_GROUP
environment
variable.
Solution:
The NIS_GROUP
environment
variable needs to be set to the group name of the administrator who will administer
the contexts.
