System Administration Guide: Naming and Directory Services (FNS and NIS+)
Corrupted Credentials
When a principal (user or machine) has a corrupt credential, that principal is unable to perform any namespace operations or tasks, not even nisls. This is because a corrupt credential provides no permissions at all, not even the permissions granted to the nobody class.
Symptoms:
User or root cannot perform any namespace tasks or operations. All namespace operations fail with a “permission denied” type of error message. The user or root cannot even perform a nisls operation.
Possible Cause:
Corrupted keys or a corrupt, out-of-date, or otherwise incorrect /etc/.rootkey file.
Diagnosis:
Use snoop to identify the bad credential.
Or, if the principal is listed, log in as the principal and try to run an NIS+ command on an object for which you are sure that the principal has proper authorization. For example, in most cases an object grants read authorization to the nobody class. Thus, the nisls object command should work for any principal listed in the cred table. If the command fails with a “permission denied” error, then the principal's credential is likely corrupted.
Solution
