The fnattr command can be used to add, delete or modify attributes associated with a name. You can make modifications one at a time, or batch several within the same command.
fnattr [-l] name to list attributes for name.
fnattr name -a-s -U -O attrib values to add an attribute
fnattr name -m -O -U attrib oldvalue newvalue to modify an attribute
fnattr name -d -O | -U [values attrib] to destroy an attribute
| Option | Description |
| name | The composite name. |
| attrib | The identifier of an attribute. |
| values | One or more attribute values. |
| oldvalue | An attribute value to be replaced by a new value. |
| newvalue | The attribute value that replaces an old value. |
| -a | Add an attribute. |
| -d | Destroy an attribute. |
| -l | List attributes. |
| -m | Modify an attribute. |
| -s | Replace all old attribute values with the new values for the attribute specified. |
| -O | The identifier format is FN_ID_ISO_OID_STRING, an ASN.1 dot-separated integer list string. |
| -U | The identifier format is FN_ID_DCE_UUID, a DCE UUID in string form. |
For example:
To show all of the attributes associated with the user name rosa:
| # fnattr user/rosa |
To display the size attribute associated with the user uri:
| # fnattr user/uri/ size |
For a user named devlin, to add an attribute named shoesize with a value of small, delete the hatsize attribute, and change the dresssize attribute value from 12 to 8:
| # fnattr user/devlin -a shoesize small -d hatsize -m dresssize 12 8 |
