The fncreate command is used to create contexts.
fncreate -t context [-f file] [-o] [-r reference] [-s] [-v] [-D] name |
Option |
Description |
-t context |
Create context of type context. Context types can be: org, hostname, host, username, user, service, fs, site, nsid, and generic. |
-f file |
Use an input file to list users and hosts for whom to create contexts. |
-r reference |
Type of reference. The -r reference option can only be used with -t generic. |
name |
A composite name. |
-o |
Create only the context identified by name. |
-s |
Overwrite (supersede) any existing binding. If -s is not used, fncreate will fail if name is already bound. |
-D |
Display information about each context and corresponding tables, directories, and files as it is created. |
-v |
Verbose. Display information about each context as it is displayed. |
For example:
To create a context and subcontexts for the root organization:
# fncreate -t org org// |
To create a context, and subcontexts, for the host deneb:
# fncreate -t host host/deneb |
To create a context, service and file subcontexts, and then add a calendar binding for the user sisulu:
# fncreate -t user user/sisulu # fnbind -r user/sisulu onc_calendar onc_cal_str sisulu@deneb |
To create a site context for the sales organization:
# fncreate -t site org/sales/site/ |
The site context supports a hierarchal namespace, with dot-separated right-to-left names, which allows sites to be partitioned by their geographical coverage relationships. For example, to create a site context alameda and a site subcontext bldg-6.alameda for it:
# fncreate -t site org/sales/site/alameda # fncreate -t site org/sales/site/bldg-6.alameda |
