System Administration Guide: Naming and Directory Services (FNS and NIS+)
Searching for Objects in a Context
The example below shows how to search for objects in a context with a specific attribute identifier and value.
#include <stdio.h>
#include <xfn/xfn.h>
#include <string.h>
#include <stdlib.h>
 This routine searchs for objects in a context
 which has the specified attribute identifier and value.
typedef struct fns_search_results {
	char *name;
	struct fns_search_results *next;
} fns_search_results;
static const char *attr_id_syntax = "fn_attr_syntax_ascii";
fns_attr_search(const char *name,
	const char *attr_id,
	const char *attr_value)
	FN_status_t *status;
	FN_ctx_t *initial_context;
	FN_composite_name_t *context_name;
	FN_searchlist_t *search_list;
	FN_string_t *search_name;
	FN_attribute_t *attribute;
	FN_attrset_t *attrset;
	FN_identifier_t identifier, syntax;
	FN_attrvalue_t *values;
	unsigned stat;
	fns_search_results *head = 0, *current, *prev;
	int no_names = 0;
	context_name = fn_composite_name_from_str((unsigned char *) name);
	status = fn_status_create();
	initial_context = fn_ctx_handle_from_initial(0, status);
	if (!fn_status_is_success(status)) {
		fprintf(stderr, "Unable to obtain intial context\n");
		return (0);
	/* Construnct the attrset with attributes to be searched */
	/* First, the identifier */
	identifier.format = FN_ID_STRING;
	identifier.length = strlen(attr_id);
	identifier.contents = (void *) strdup(attr_id);
	/* Second, the syntax */
	syntax.format = FN_ID_STRING;
	syntax.length = strlen(attr_id_syntax);
	syntax.contents = (void *) strdup(attr_id_syntax);
	/* Third, the attribute value */
	values = (FN_attrvalue_t *) malloc(sizeof(FN_attrvalue_t));
	values->length = strlen(attr_value);
	values->contents = (void *) strdup(attr_value);
	/* Fourth, create the attribute */
	attribute = fn_attribute_create(&identifier, &syntax);
	/* Fifth, add the attribute value */
	fn_attribute_add(attribute, values, 0);
	/* Sixth, create attrset, and add the attribute */
	attrset = fn_attrset_create();
	fn_attrset_add(attrset, attribute, 0);
	search_list = prelim_fn_attr_search(initial_context,
	 context_name, attrset, 0, 0, status);
		fprintf(stderr, "Unable to list names\n");
		return (0);
	while (search_name = prelim_fn_searchlist_next(search_list,
	 0, 0, status)) {
		no_names++;
		current = (fns_search_results *)
    malloc(sizeof(fns_search_results));
		current->name = (char *)
		 malloc(strlen((char *) fn_string_str(search_name, &stat)) + 1);
		strcpy(current->name, (char *) fn_string_str(search_name, &stat));
		current->next = 0;
		if (head) {
			prev->next = current;
			prev = current;
		} else {
			head = current;
			prev = current;
		fn_string_destroy(search_name);
	fn_searchlist_destroy(search_list);
	fn_status_destroy(status);
	fn_ctx_destroy(initial_context);
	fn_attrset_destroy(attrset);
	fn_attribute_destroy(attribute);
	free(identifier.contents);
	free(syntax.contents);
	free(values->contents);
	free(values);
	return (head);
