System Administration Guide: Naming and Directory Services (FNS and NIS+)
Structure of the Enterprise Namespace
FNS policies define the structure of the enterprise namespace. The purpose of this structure is to allow easy and uniform composition of names. This enterprise namespace structure has two main rules:
Table 25–26 isf FNS policies for arranging the enterprise namespace. The following table shows an example of a namespace layout that follows these FNS policies.
Table 25–26 Policies for the Federated Enterprise Namespace
Namespace Identifiers
Subordinate Namespaces
Parent Context
Namespace Organization
Syntax
orgunit
_orgunit
org
Site, user, host, file system, service
Enterprise root
Hierarchical
Dot-separated right-to-left
site
_site
Service, file system
Enterprise root, organizational unit
Hierarchical
user
_user
Flat
Solaris login name
host
_host
Flat
Solaris host name
service
_service
Application specific
Enterprise root, organizational unit, site, user, host
Hierarchical
/ separated left-to-right
fs
_fs
None
Hierarchical
/ separated, left-to-right
printer
None
Service
Hierarchical
Figure 25–1 Example of an Enterprise Namespace
Graphic
The namespace of an enterprise is structured around a hierarchy of organizational units. Names of sites, hosts, users, files, and services can be named relative to names of organizational units by composing the organizational unit name with the appropriate namespace identifier and object name.
In Figure 25–2, a user myoko in the west division of the sales organization of an enterprise is named using the name orgunit/west.sales/user/myoko.
Note the use of the namespace identifier user to denote the transition from the orgunit namespace to the user namespace. In a similar fashion (with the use of appropriate namespace identifiers), names of files and services can also be named relative to names of sites, users, or hosts. Names of sites can be named relative to organizational unit names.
The goal of easy and uniform composability of names is met using this structure. For example, once you know the name for an organizational unit within an enterprise (for example, orgunit/west), you can name a user relative to it by composing it with the user namespace identifier and the user's login name to yield a name such as orgunit/west/user/josepha.
To name a file in this user's file system, you can use a name like orgunit/west/user/josepha/fs/notes.
