System Administration Guide: Naming and Directory Services (FNS and NIS+)
How to Initialize a Client—Host-name Method
  1. Check the client's /etc/hosts or /etc/inet/ipnodes file.
    Make sure the client has an entry for the trusted server.
  2. Initialize the client.
    This step initializes the client and creates a NIS_COLD_START file in its /var/nis directory. Use the nisinit command with the -c and -H options. This example uses rootmaster as the trusted server.
    Client1# nisinit -c -H rootmaster
    This machine is in the doc.com. NIS+ domain.
    Setting up NIS+ client ...
    All done.
    The nisinit utility looks for the server's address in the client's /etc/hosts or /etc/inet/ipnodes file, so do not append a domain name to the server. If you do, the utility will not be able to find its address.
