Copy the other client's cold-start file.
Copy the other client's cold-start file into a directory in the new client. This may be easier to do while logged on as yourself rather than as superuser on the client. Be sure to switch back to superuser before initializing the client.
Don't copy the NIS_COLD_START file into /var/nis, because that file gets overwritten during initialization. This example copies the cold-start file of previously initialized client1 into the /tmp directory of uninitialized client2.
client2# exit client2% rcp client1:/var/nis/NIS_COLD_START /tmp client2% su |
Initialize the client from the cold-start file.
Use the nisinit command with the -c and -C options.
client2# nisinit -c -C /tmp/NIS_COLD_START This machine is in the doc.com. NIS+ domain. Setting up NIS+ client ... All done. |
