System Administration Guide: Naming and Directory Services (FNS and NIS+)
/etc/default/rpc.nisd
All assignments in the /etc/default/rpc.nisd file are of the attributeName=value type.
General Configuration
The following attributes control general configuration of the rpc.nisd, and are active whether or not LDAP mapping is in effect. They should generally be left at their default values. See rpc.nisd(4) for more information.
Configuration Data From LDAP
The following attributes control the reading of other configuration attributes from LDAP. These attributes cannot themselves reside in LDAP. They are read only from the command line or the configuration file. See rpc.nisd(4) for more information.
Server Selection
Authentication and Security
The authentication method and, if appropriate for the method selected, the proxy user (bind distinguished name [DN]) and password (key or other shared secret) to be used between the rpc.nisd daemon and the LDAP server. See Security and Authentication for more information.
Optionally use SSL, and specify the location of the certificate file. See Using SSL for more information.
Default Location in LDAP and NIS+
Timeout/Size Limits and Referral Action for LDAP Communication
The above parameters are timeouts for the ldap bind, modify, add, and delete operations, respectively. They should generally be left at their default values.
The above parameters set the timeout for the LDAP search operation, and request a server-side search time limit, respectively. Since the nisplusLDAPsearchTimeLimit will control how much time the LDAP server spends on the search request, make sure that nisplusLDAPsearchTimeLimit is not smaller than nisplusLDAPsearchTimeout. Depending on the performance of the NIS+ server, the LDAP server, and the connection between them, you might have to increase the search limits from the default values. Watch for timeout syslog messages from rpc.nisd as a clue to making these values larger.
Error Actions
The following parameters define the actions to take when an error occurs during an LDAP operation. You should generally leave these at their defaults. See rpc.nisd(4) for more information.
General LDAP Operation Control
