The two tables in this section contain NIS commands and their approximate NIS+ equivalents. The commands have been divided into two categories: Table 26–11 contains name service client commands and Table 26–12 contains name service server commands.
Table 26–11 shows client-to-name server commands. These commands are typed on name service client machines and request information of name service servers. The commands in column 1 run on Solaris 1, Solaris 2 or Solaris 9 NIS clients connected to Solaris 1 NIS servers. The commands in column 2 run on Solaris 1, Solaris 2, or Solaris 9 NIS clients connected to Solaris 2 or Solaris 9 NIS+ servers running in NIS-compatibility mode. The commands in column 3 only run on Solaris 2 or Solaris 9 NIS+ clients connected to Solaris 2 or Solaris 9 NIS+ servers. Commands are approximately equivalent across rows. “N/A” indicates that an equivalent command does not exist for that case.
Table 26–11 NIS Client Commands and Equivalent NIS+ Commands
SunOS 4.x NIS Server |
NIS+ Server in NIS-Compatibility Mode |
NIS+ Server |
ypwhich -m |
ypwhich -m |
niscat -o org_dir |
ypcat |
ypcat |
niscat |
ypwhich |
ypwhich |
N/A |
ypmatch |
ypmatch |
nismatch/nisgrep |
yppasswd |
passwd |
passwd |
ypbind |
ypbind |
N/A |
yppoll |
N/A |
N/A |
ypset |
ypset |
N/A |
N/A |
ypinit -c |
nisclient -c |
Note that:
In the Solaris 2.5 release, the passwd command should be used regardless of NIS or NIS+ status. The functions previously performed by nispasswd and yppasswd have now been included in the passwd command.
The ypinit -c command is available only on Solaris 2 or Solaris 9 NIS clients.
The ypcat command is not supported for
queries directed to the netgroup table. The NIS client's request times out
before an answer is received because this table's format is so different
from the netgroup
NIS map's format.
Table 26–12 shows name server-to-name server commands. The NIS server commands are not included in the Solaris 2 or Solaris 9 releases, so they are not available to either NIS+ servers or NIS+ servers in NIS-compatibility mode. In addition, an NIS server cannot make updates to an NIS+ server, nor can an NIS+ server make updates to an NIS server. Column 3 lists the NIS+ server commands that are equivalent to the NIS server commands in column 1. Servers in NIS-compatibility mode have no exact equivalents because NIS-compatibility mode refers only to client commands.
Table 26–12 NIS Server Commands and Equivalent NIS+ Commands
NIS+ Server |
ypxfr |
N/A |
N/A |
makedbm |
N/A |
nisaddent |
ypinit -m ypinit -s |
N/A |
nisserver |
ypserv |
rpc.nisd -Y |
rpc.nisd |
ypserv -d |
rpc.nisd -Y -B |
No DNS forwarding needed; use /etc/nsswitch.conf |
ypxfrd |
N/A |
N/A |
rpc.ypupdated |
N/A |
N/A |
rpc.yppasswd |
rpc.nispasswdd |
rpc.nispasswdd |
yppush |
N/A |
nisping |
ypmake |
N/A |
nissetup, nisaddent |
ypxfr |
N/A |
N/A |
