次の例では、format ユーティリティを使用して1G バイトのディスクを 3 つのスライスに分割します。各スライスをルート (/) ファイルシステム、スワップ領域、/usr ファイルシステムに割り当てます。
# format Searching for disks...done AVAILABLE DISK SELECTIONS: 0. c0t1d0 <SUN1.05 cyl 2036 alt 2 hd 14 sec 72> /iommu@f,e0000000/sbus@f,e0001000/espdma@f,400000/esp@f,800000/sd@1,0 1. c0t3d0 <SUN1.05 cyl 2036 alt 2 hd 14 sec 72> /iommu@f,e0000000/sbus@f,e0001000/espdma@f,400000/esp@f,800000/sd@3,0 Specify disk (enter its number): 0 selecting c0t1d0 [disk formatted] format> partition partition> print partition> modify Select partitioning base: 0. Current partition table (original) 1. All Free Hog Choose base (enter number) [0]? 1 Part Tag Flag Cylinders Size Blocks 0 root wm 0 0 (0/0/0) 0 1 swap wu 0 0 (0/0/0) 0 2 backup wu 0 - 2035 1002.09MB (2036/0/0) 2052288 3 unassigned wm 0 0 (0/0/0) 0 4 unassigned wm 0 0 (0/0/0) 0 5 unassigned wm 0 0 (0/0/0) 0 6 usr wm 0 0 (0/0/0) 0 7 unassigned wm 0 0 (0/0/0) 0 Do you wish to continue creating a new partition table based on above table[yes]? yes Free Hog partition[6]? 6 Enter size of partition `0' [0b, 0c, 0.00mb]: 200mb Enter size of partition `1' [0b, 0c, 0.00mb]: 200mb Enter size of partition `3' [0b, 0c, 0.00mb]: Enter size of partition `4' [0b, 0c, 0.00mb]: Enter size of partition `6' [0b, 0c, 0.00mb]: Enter size of partition `7' [0b, 0c, 0.00mb]: Part Tag Flag Cylinders Size Blocks 0 root wm 0 - 406 200.32MB (407/0/0) 410256 1 swap wu 407 - 813 200.32MB (407/0/0) 410256 2 backup wu 0 - 2035 1002.09MB (2036/0/0) 2052288 3 unassigned wm 0 0 (0/0/0) 0 4 unassigned wm 0 0 (0/0/0) 0 5 unassigned wm 0 0 (0/0/0) 0 6 usr wm 814 - 2035 601.45MB (1222/0/0) 1231776 7 unassigned wm 0 0 (0/0/0) 0 Okay to make this the current partition table[yes]? yes Enter table name (remember quotes): "disk0" Ready to label disk, continue? yes partition> quit format> verify format> quit |
