仕様では次の決まりが使用されます。
空白は項目と項目の区切りに使用し、意味を持たない
定数は 1 つ以上の 10 進数のシーケンスで、次のコーディング例のように、オプションで先頭にマイナス記号 (-) を付けることができる。
Syntax Information
declaration:
type-specifier identifier
| type-specifier identifier "[" value "]"
| type-specifier identifier "<" [ value ] ">"
| "opaque" identifier "[" value "]"
| "opaque" identifier "<" [ value ] ">"
| "string" identifier "<" [ value ] ">"
| type-specifier "*" identifier
| "void"
value:
constant
| identifier
type-specifier:
[ "unsigned" ] "int"
| [ "unsigned" ] "hyper"
| "float"
| "double"
| "quadruple"
| "bool"
| enum-type-spec
| struct-type-spec
| union-type-spec
| identifier
enum-type-spec:
"enum" enum-body
enum-body:
( identifier "=" value )
( "," identifier "=" value )*
struct-type-spec:
"struct" struct-body
struct-body:
( declaration ";" )
( declaration ";" )*
union-type-spec:
"union" union-body
union-body:
"switch" "(" declaration ")" "{"
( "case" value ":" declaration ";" )
( "case" value ":" declaration ";" )*
[ "default" ":" declaration ";" ]
constant-def:
"const" identifier "=" constant ";"
type-def:
"typedef" declaration ";"
| "enum" identifier enum-body ";"
| "struct" identifier struct-body ";"
| "union" identifier union-body ";"
definition:
type-def
| constant-def
specification:
definition *
