The following table lists the generic tasks for obtaining information about traffic flows by using the flowacct module.
Table 5–1 Configuring Flow Accounting (Task Map)
Task |
Description |
For Instructions |
1. Create a file to contain accounting information for traffic flows. |
Use the acctadm command to create a file that holds the results of processing by flowacct. | |
2. Define flowacct parameters in the IPQoS configuration file. |
Define values for the timer, timeout, and max_limit parameters. |
How to Enable Accounting for a Class in the IPQoS Configuration File |
3. View the contents of the file. |
View an example program that can be used to create a utility to read accounting records from a file. |
