This section introduces the elements that are involved in forwarding packets on an IPQoS-enabled network. An IPQoS-enabled system handles any packets on the network stream with the system's IP address as the destination. The IPQoS system then applies its QoS policy to the packet to establish differentiated services.
The DS codepoint defines in the packet header the action that any diffserv-aware system should take on a marked packet. The diffserv architecture defines a set of DS codepoints and corresponding actions, or forwarding behaviors, for the IPQoS-enabled system and router to use. The IPQoS-enabled system marks the precedence bits of the DS field in the packet header with the DSCP. When a router receives a packet with a DSCP value, the router applies the forwarding behavior associated with that DSCP as the packet is released onto the network.
The dlcosmk meter does not use the DSCP. Rather, dclosmk marks Ethernet frame headers with a CoS value. If you plan to configure IPQoS on a network that uses VLAN devices, refer to Marker Module.
In diffserv terminology, the forwarding behavior that is assigned to a DSCP is called the per-hop behavior (PHB).The PHB defines the forwarding precedence a marked packet receives in relation to other traffic on the diffserv-aware system. This precedence ultimately determines whether the IPQoS-enabled system or diffserv router forwards or drops the marked packet. For a forwarded packet, each diffserv router that the packet encounters en route to its destination applies the same PHB. The exception is if another diffserv system changes the DSCP. For more information on PHBs, refer to Using the dscpmk Marker for Forwarding Packets.
The goal of a PHB is to provide a specified amount of network resources to a class of traffic on the contiguous network. You can achieve this goal in the QoS policy by defining DS codepoints that indicate the precedence levels for traffic classes when they leave the IPQoS-enabled system. Precedences range from high-precedence/low-drop probability to low-precedence/high-drop probability.
For example, your QoS policy can assign to one class of traffic a DSCP that guarantees a low-drop PHB. This traffic class then receives a low-drop precedence PHB from any diffserv-aware router, which guarantees bandwidth to packets of this class. You can add to the QoS policy other DSCPs that assign varying levels of precedence to other traffic classes. The lower-precedence packets are given bandwidth by diffserv systems in agreement with the priorities that are indicated in the packets' DSCPs.
IPQoS supports two types of forwarding behaviors, which are defined in the diffserv architecture, expedited forwarding and assured forwarding.
The expedited forwarding (EF) per-hop behavior assures that any traffic class with EF's related DSCP is given highest priority and is not queued. EF provides low loss, latency, and jitter. The recommended DS codepoint for EF is 101110. A packet that is marked with 101110 receives guaranteed low-drop precedence as the packet traverses diffserv-aware networks en route to its destination. Use the EF DSCP when assigning priority to customers or applications with a premium SLA.
The assured forwarding (AF) per-hop behavior provides four different forwarding classes that you can assign to a packet. Each forwarding class provides three drop precedences, as shown in Table 6–2.
The various AF codepoints provide the ability to assign different levels of services to customers and applications. In the QoS policy you can prioritize traffic and services on your network when you plan the QoS policy. You can then assign different AF levels to the prioritized traffic.
The following figure shows part of an intranet at a company with a partially diffserv-enabled environment. In this scenario, all hosts on networks 10.10.0.0 and 10.14.0.0 are IPQoS-enabled, and the local routers on both networks are diffserv-aware. However, the interim networks are not configured for diffserv.
The next steps trace the flow of the packet that is shown in the previous figure. The steps begin with the progress of a packet that originates at host ipqos1 and continues through several hops to ipqos2.
The user on ipqos1 runs the ftp command to access host ipqos2, three hops away.
ipqos-1 applies its QoS policy to the resulting packet flow and successfully classifies the ftp traffic.
The system administrator has created a class for all outgoing ftp traffic that originates on the local network 10.10.0.0. Traffic for the ftp class is assigned the AF22 per-hop behavior: class two, medium-drop precedence. A traffic flow rate of 2Mbits per second is configured for the ftp class.
ipqos-1 meters the ftp flow to determine if it exceeds the committed rate of 2 Mbits per second.
The marker on ipqos1 marks the DS fields in the outgoing ftp packets with the 010100 DSCP, corresponding to the AF22 PHB.
The router diffrouter1 receives the ftp packets and checks the DSCP. If diffrouter1 is congested, it drops the packets that are marked with AF22.
ftp traffic is forwarded to the next hop in agreement with the per-hop behavior that is configured for AF22 in diffrouter1's files.
The ftp traffic traverses network 10.12.0.0 to genrouter, which is not diffserv-aware. As a result, the traffic receives “best-effort” forwarding behavior.
genrouter passes the ftp traffic to network 10.13.0.0, where the traffic is received by diffrouter2.
diffrouter2 is diffserv-aware. Therefore, the router forwards the ftp packets to the network in agreement with the PHB that is defined in the router policy for AF22 packets.
ipqos2 receives the ftp traffic and prompts the user on ipqos1 for a user name and password.
