This section contains a table of error messages that are generated by IPQoS and their possible solutions.
Table 4–2 IPQoS Error Messages|
Error Message |
Description |
Solution |
Undefined action in parameter parameter-name's action action-name |
In the IPQoS configuration file, the action name that you specified in parameter-name does not exist in the configuration file. |
Create the action or refer to a different, existing action in the parameter. |
action action-name involved in cycle |
In the IPQoS configuration file, action-name is part of a cycle of actions, which is not allowed by IPQoS. |
Determine the action cycle and remove one of the cyclical references from the IPQoS configuration file. |
Action action-name isn't referenced by any other actions |
A non-ipgpc action definition is not referenced by any other defined actions in the IPQoS configuration, which is not allowed by IPQoS. |
Remove the unreferenced action or make another action reference the currently unreferenced action. |
Missing/Invalid config file fmt_version |
The format of the configuration file is not specified as the first entry of the file, which is required by IPQoS. |
Add the format version, as explained in How to Begin the IPQoS Configuration File and Define Traffic Classes. |
Unsupported config file format version |
The format version that is specified in the configuration file is not supported by IPQoS. |
Change the format version to fmt_version 1.0, which is required to run the Solaris 9 9/02 version of IPQoS. |
No ipgpc action defined. |
You did not define an action for the ipgpc classifier in the configuration file, which is an IPQoS requirement. |
Define an action for ipgpc, as shown in How to Begin the IPQoS Configuration File and Define Traffic Classes. |
Can't commit a null configuration |
When you ran ipqosconf -c to commit a configuration, that configuration was empty, which IPQoS does not allow. |
Be sure to apply a configuration file before you attempt to commit a configuration. |
Invalid CIDR mask on line line_number |
In the configuration file, you used a CIDR mask as part of the IP address that is out of the valid range for IP addresses. |
Change the mask value to be in the range of 1–32 for IPv4 and 1–128 for IPv6. |
Address masks aren't allowed for host names line line_number |
In the configuration file, you defined a CIDR mask for a host name, which is not allowed in IPQoS. |
Remove the mask or change the host name to an IP address. |
Invalid module name line line_number |
In the configuration file, the module name you specified in an action statement is invalid. |
Check the spelling of the module name. For a list of IPQoS modules, refer to Table 6–5. |
ipgpc action has incorrect name line line_number |
The name that you gave to the ipgpc action in the configuration file is not the required ipgpc.classify. |
Rename the action ipgpc.classify. |
Second parameter clause not supported line line_number |
In the configuration file, you specified two parameter clauses for a single action, which IPQoS does not allow. |
Combine all parameters for the action into a single parameters clause. |
Duplicate named action |
In the configuration file, you gave the same name to two actions. |
Rename or remove one of the actions. |
Duplicate named filter/class in action action_name |
You gave the same name to two filters or two classes in the same action, which is not allowed in the IPQoS configuration file. |
Rename or remove one of the filters or classes. |
Undefined class in filter filter_name in action action_name |
In the configuration file, the filter references a class that is not defined in the action. |
Create the class, or change the filter reference to an already existing class. |
Undefined action in class class_name action action_name |
The class refers to an action that is not defined in the configuration file. |
Create the action, or change the reference to an already existing action. |
Invalid parameters for action action_name |
In the configuration file, one of the parameters is invalid. |
For the module that is called by the named action, refer to the module entry in IPQoS Architecture and the diffserv Model. Alternatively, you can refer to the ipqosconf(1M) man page. |
Mandatory parameter missing for action action_name |
You have not defined a required parameter for an action in the configuration file. |
Max number of classes reached in ipgpc |
You specified more classes than are allowed in the ipgpc action of the IPQoS configuration file. The maximum number is 10007. |
Review the configuration file and remove unneeded classes. Alternatively, you can raise the maximum number of classes by adding to the /etc/system file the entry ipgpc_max_classes class_number. |
Max number of filters reached in action ipgpc |
You specified more filters than are allowed in the ipgpc action of the IPQoS configuration file. The maximum number is 10007. |
Review the configuration file and remove unneeded filters. Alternatively, you can raise the maximum number of filters by adding to the /etc/system file the entry ipgpc_max_filters class_number. |
Invalid/missing parameters for filter filter_name in action ipgpc. |
In the configuration file, filter filter_name has an invalid or missing parameter. |
Refer to the ipqosconf(1m) man page for the list of valid parameters. |
Name not allowed to start with '!', line line_number |
You began an action, filter, or class name with an exclamation mark (!), which is not allowed in the IPQoS file. |
Remove the exclamation mark or rename the action, class, or filter. |
Name exceeds the maximum name length line line_number |
You defined a name for an action, class, or filter in the configuration file that exceeds the maximum length of 23 characters. |
Give a shorter name to the action, class, or filter. |
Array declaration line line_number is invalid |
In the configuration file, the array declaration for the parameter on line line_number is invalid. |
For the correct syntax of the array declaration that is called by the action statement with the invalid array, refer to IPQoS Architecture and the diffserv Model. Alternatively, refer to the ipqosconf(1m) man page. |
Quoted string exceeds line, line_number |
The string does not have the terminating quotation marks on the same line, which is required in the configuration file. |
Make sure that the quoted string begins and ends on the same line in the configuration file. |
Invalid value, line line_number |
The value that is given on line_number of the configuration file is not supported for the parameter. |
For the acceptable values for the module that is called by the action statement, refer to module description in IPQoS Architecture and the diffserv Model. Alternatively, you can refer to the ipqosconf(1m) man page. |
Unrecognized value, line line_number |
The value on line_number of the configuration file is not a supported enumeration value for its parameter. |
Check that the enumeration value is correct for the parameter. For a the description of the module that is called by the action statement with the unrecognized line number, refer to IPQoS Architecture and the diffserv Model. Alternatively, you can refer to the ipqosconf(1m) man page. |
Malformed value list line line_number |
The enumeration that is specified on line_number of the configuration file does not conform to the specification syntax. |
For correct syntax of the module that is called by the action with the malformed value list, refer to the module description in IPQoS Architecture and the diffserv Model. Alternatively, you can refer to the ipqosconf(1m) man page. |
Duplicate parameter line line_number |
A duplicate parameter was specified on line_number, which is not allowed in the configuration file. |
Remove one of the duplicate parameters. |
Invalid action name line line_number |
You gave the action on line_number of the configuration file a name that uses the predefined name “continue” or “drop.” |
Rename the action so that it does not use a predefined name. |
Failed to resolve src/dst host name for filter at line line_number, ignoring filter |
ipqosconf could not resolve the source or destination address that was defined for the given filter in the configuration file. Therefore, the filter is ignored. |
If the filter is important, try applying the configuration at a later time. |
Incompatible address version line line_number |
The IP version of the address on line_number is incompatible with the version of a previously specified IP address or ip_version parameter in the configuration file. |
Change the two conflicting entries to be compatible. |
Action at line line_number has the same name as currently installed action, but is for a different module |
You tried to change the module of an action that already exists in the system's IPQoS configuration, which is not allowed. |
Flush the current configuration before you apply the new configuration. |
