To configure a two-rate tokenmt to be color aware, you must add parameters to specifically add “color awareness.” The following is an example action statement that configures color-aware tokenmt.
action {
module tokenmt
name meter1
params {
committed_rate 4000000
peak_rate 8000000
committed_burst 4000000
peak_burst 8000000
global_stats true
red_action_name continue
yellow_action_name continue
green_action_name continue
color_aware true
color_map {0-20,22:GREEN;21,23-42:RED;43-63:YELLOW}
You turn on color awareness by setting the color_aware parameter to true. As a color-aware meter, tokenmt assumes that the packet has already been marked as red, yellow, or green by a previous tokenmt action. Color-aware tokenmt evaluates a packet by using the DS codepoint in the packet header in addition to the parameters for a two-rate meter.
The color_map parameter contains an array into which the DSCP in the packet header is mapped. Consider the following color_map array:
Packets with a DSCP of 0–20 and 22 are mapped to green. Packets with a DSCP of 21 and 23–42 are mapped to red. Packets with a DSCP of 43–63 are mapped to yellow. tokenmt maintains a default color map, but you can change it as needed by using the color_map parameters.
In the color_action_name parameters, you can specify continue to complete processing of the packet. Or you can add an argument to send the packet to a marker action, for example, yellow_action_name mark22.
