You use action statements to invoke the various IPQoS modules that are described in IPQoS Architecture and the diffserv Model.
When you begin the IPQoS configuration file, you must always begin with the version number. Then, you must add the following action to invoke the classifier:
fmt_version 1.0
action {
module ipgpc
name ipgpc.classify
Use the following syntax for all other action statements:
action {
name action_name
module module_name
params_clause | ""
cf_clauses
Statement |
Definition |
name action_name |
Assigns a name to the action |
module module_name |
Identifies the IPQoS module to be invoked, which must be one of the modules in Table 6–5 |
params_clause |
Can be parameters for the classifier to process, such as global statistics or the next action to process |
cf_clauses |
A set of zero or more class clauses or filter clauses |
