You use the ipqosconf utility to read the IPQoS configuration file and configure IPQoS modules in the UNIX kernel. ipqosconf can perform the following actions:
Apply the configuration file to the IPQoS kernel modules (ipqosconf -a) filename
List the IPQoS configuration file currently resident in the kernel (ipqosconf -l)
Ensure that the current IPQoS configuration is read and applied each time the machine reboots (ipqosconf -c)
Flush the current IPQoS kernel modules (ipqosconf -f)
For technical information, refer to the ipqosconf(1M) man page.
