The IPQoS flowacct module records information about traffic flows, a process that is referred to as flow accounting. The results of flow accounting are data that can be used for billing customers or for evaluating the amount of traffic to a particular class.
Flow accounting is optional. flowacct is typically the final module that metered or marked traffic flows might encounter before release onto the network stream. For an illustration of flowacct's position in the diffserv model, see Figure 1–1. For detailed technical information about flowacct, refer to the flowacct(7ipp) man page.
To enable flow accounting, you need to use the Solaris exacct accounting facility and the acctadm command, as well as flowacct. For the overall steps in setting up flow accounting, refer to Table 5–1.
flowacct gathers information about flows in a flow table that is composed of flow records. Each entry in the table contains one flow record. You cannot display a flow-account table.
In the IPQoS configuration file, you define the following flowacct parameters to measure flow records and to write them to the table:
timer – Defines an interval, in milliseconds, when timed-out flows are removed from the flow table and written to the file that is created by acctadm
timeout – Defines a interval, in milliseconds, that specifies how long a packet flow must be inactive before it times out
You can configure timer and timeout to have different values.
max_limit – Places an upper limit on the number of flow records that can be stored in the table
The flowacct module maintains a flow table that records all packet flows that are seen by a flowacct instance. A flow is identified by the following parameters, which comprise the flowacct 8–tuple.
Source address
Destination address
Source port
Destination port
DSCP
User ID
Project ID
Protocol
If all the parameters of the 8–tuple for a flow remain the same, the flow table contains only one entry. The max_limit parameter determines the number of entries that a flow table can contain.
The flow table is scanned at the interval that is specified in the IPQoS configuration file for the timer parameter. The default is 15 seconds. A flow “times out” when its packets are not seen by the IPQoS system for at least the timeout interval in the IPQoS configuration file. The default time-out interval is 60 seconds. Entries that have timed out are then written to the accounting file that is created with the acctadm command.
A flowacct record contains the following attributes.
Table 6–4 Attributes of a flowacct Record|
Attribute Name |
Attribute Contents |
Type |
src -addr-address_type |
Source address of the originator. address_type is either v4 for IPv4 or v6 for IPv6, as specified in the IPQoS configuration file. |
Basic |
dest_ addr_address_type |
Destination address for the packets. address_type is either v4 for IPv4 or v6 for IPv6, as specified in the IPQoS configuration file. |
Basic |
src- port |
Source port from which the flow originated. |
Basic |
dest-port |
Destination port number to which this flow is bound. |
Basic |
protocol |
Protocol number for the flow. |
Basic |
total-packets |
Number of packets in the flow. |
Basic |
total-bytes |
Number of bytes in the flow. |
Basic |
action_name |
Name of the flowacct action that recorded this flow. |
Basic |
creation_time |
First time that a packet is seen for the flow by flowacct. |
Extended only |
last_seen |
Last time that a packet of the flow was seen. |
Extended only |
diffserv-field |
DS codepoint in the outgoing packet headers of the flow. |
Extended only |
user |
Either a UNIX UserID or user name, which is obtained from the application. |
Extended only |
projid |
Project ID, which is obtained from the application. |
Extended only |
You use the acctadm command to create a file in which to store the various flow records that are generated by flowacct. acctadm works in conjunction with the extended accounting facility. For technical information about acctadm, refer to the acctadm(1M) man page.
flowacct observes flows and fills its table with flow records. flowacct then evaluates its parameters and attributes in the interval that is specified by timer. When a packet is not seen for at least the last_seen plus timeout values, the packet times out. All timed-out entries are deleted from the flow table. They are then written to the accounting file each time the interval that is specified in the timer parameter elapses.
To invoke acctadm for use with the flowacct module, use the following syntax:
acctadm -e type -f filename flow
acctadm -e |
Invokes acctadm with the -e option. The -e indicates that a resource list follows. |
type |
Specifies the attributes to be gathered. file-type must be replaced by either basic or extended. For a list of attributes in each file type, refer to Table 6–4. |
-f file_name |
Creates the file file_name to hold the flow records. |
flow |
Indicates that acctadm is to be run with IPQoS. |
