Solaris Volume Manager Administration Guide
Limitations to Large Volume Support
Solaris Volume Manager only supports large volumes (>1 TB) on Solaris 9 4/03 or later when running a 64–bit kernel. Running a system with large volumes under 32–bit kernel on previous Solaris 9 releases will affect Solaris Volume Manager functionality. Specifically, note the following:
Caution – Caution –
Do not create large volumes if you expect to run the Solaris Operating Environment with a 32–bit kernel or if you expect to use a version of the Solaris Operating Environment prior to Solaris 9 4/03.
