Solaris Volume Manager Administration Guide
Background Information For Replacing and Enabling Slices in Mirrors and RAID 5 Volumes
When you replace components in a mirror or a RAID 5 volume, follow these guidelines:
Note –
A submirror or RAID 5 volume might be using a hot spare in place of a failed component. When that failed component is enabled or replaced by using the procedures in this section, the hot spare is marked “Available” in the hot spare pool, and is ready for use.
