Solaris Volume Manager Administration Guide
Solaris Volume Manager Roadmap—Storage Capacity
Table 1–2 Solaris Volume Manager Roadmap—Storage Capacity
Task
Description
For Instructions
Set up storage
Create storage that spans slices by creating a RAID 0 or a RAID 5 volume. The RAID 0 or RAID 5 volume can then be used for a file system or any application, such as a database that accesses the raw device
How to Create a RAID 0 (Stripe) Volume
How to Create a RAID 0 (Concatenation) Volume
How to Create a RAID 1 Volume From Unused Slices
How to Create a RAID 1 Volume From a File System
How to Create a RAID 5 Volume
Expand an existing file system
Increase the capacity of an existing file system by creating a RAID 0 (concatenation) volume, then adding additional slices.
How to Expand Space for Existing Data
Expand an existing RAID 0 (concatenation or stripe) volume
Expand an existing RAID 0 volume by concatenating additional slices to it.
How to Expand an Existing RAID 0 Volume
Expand a RAID 5 volume
Expand the capacity of a RAID 5 volume by concatenating additional slices to it.
How to Expand a RAID 5 Volume
Increase the size of a UFS file system on a expanded volume
Grow a file system by using the growfs command to expand the size of a UFS while it is mounted and without disrupting access to the data.
How to Grow a File System
Subdivide slices or logical volumes into smaller partitions, breaking the 8 slice hard partition limit
Subdivide logical volumes or slices by using soft partitions.
How to Create a Soft Partition
Create a file system
Create a file system on a RAID 0 (stripe or concatenation), RAID 1 (mirror), RAID 5, or transactional volume, or on a soft partition.
“Creating File Systems (Tasks)” in System Administration Guide: Basic Administration
