System Administration Guide: Basic Administration
Dump Levels for Daily, Cumulative Backups
Doing daily, cumulative incremental backups is the most commonly used backup scheme and is recommended for most situations. The following example shows a schedule that uses a level 9 dump each day, and a level 5 dump on Friday to restart the process.
Figure 45–1 Incremental Backup: Daily Cumulative
Illustration shows increasing amount of tape needed for a daily cumulative backup that starts on Monday and finishes on Friday.
In the preceding example, you could have used other numbers in the 1–9 range to produce the same results. The key is having the same number each day, with any lower number on Friday. For example, you could have specified levels 4, 4, 4, 4, 2 or 7, 7, 7, 7, 5.
