The following example shows how to do a full backup of the root (/) file system. The system in this example is brought to single-user mode before the backup. The following ufsdump options are included:
0 specifies that this is a 0 level dump (or a full backup)
u specifies that the /etc/dumpdates file is updated with the date of this backup
c identifies a cartridge tape device
f /dev/rmt/0 identifies the tape device
/ is the file system being backed up
# shutdown -g30 -y # ufsdump 0ucf /dev/rmt/0 / DUMP: Writing 63 Kilobyte records DUMP: Date of this level 0 dump: Wed Sep 05 13:27:20 2001 DUMP: Date of last level 0 dump: the epoch DUMP: Dumping /dev/rdsk/c0t1d0s0 (earth:/) to /dev/rmt/0. DUMP: Mapping (Pass I) [regular files] DUMP: Mapping (Pass II) [directories] DUMP: Estimated 57150 blocks (27.91MB). DUMP: Dumping (Pass III) [directories] DUMP: Dumping (Pass IV) [regular files] DUMP: Tape rewinding DUMP: 57076 blocks (27.87MB) on 1 volume at 265 KB/sec DUMP: DUMP IS DONE DUMP: Level 0 dump on Wed Sep 05 13:27:20 2001 # ufsrestore tf /dev/rmt/0 2 . 3 ./lost+found 3776 ./usr 7552 ./var 11328 ./export 15104 ./export/home 18880 ./etc 22656 ./etc/default 22657 ./etc/default/sys-suspend 22673 ./etc/default/cron 22674 ./etc/default/devfsadm 22675 ./etc/default/dhcpagent 22676 ./etc/default/fs 22677 ./etc/default/inetinit 22678 ./etc/default/kbd 22679 ./etc/default/mpathd 22680 ./etc/default/nfslogd 22681 ./etc/default/passwd . . . # (Press Control-d to bring system to run level 3) |
