Disk and file administration commands require the use of either a raw (or character) device interface, or a block device interface. The distinction is made by how data is read from the device.
Raw device interfaces transfer only small amounts of data at a time. Block device interfaces include a buffer from which large blocks of data are read at once.
Different commands require different interfaces.
When a command requires the raw device interface, specify the /dev/rdsk subdirectory. (The “r” in rdsk stands for “raw.”)
When a command requires the block device interface, specify the /dev/dsk subdirectory.
When you are not sure whether a command requires use of /dev/dsk or /dev/rdsk, check the man page for that command.
The following table shows which interface is required for some commonly used disk and file system commands.
Table 29–1 Device Interface Type Required by Some Frequently Used Commands|
Command |
Interface Type |
Example of Use |
Block |
df /dev/dsk/c0t3d0s6 |
Raw |
fsck -p /dev/rdsk/c0t0d0s0 |
Block |
mount /dev/dsk/c1t0d0s7 /export/home |
Raw |
newfs /dev/rdsk/c0t0d1s1 |
Raw |
prtvtoc /dev/rdsk/c0t0d0s2 |
