The fdisk menu appears on IA based systems only and looks similar to the following.
format> fdisk
Total disk size is 1855 cylinders
Cylinder size is 553 (512 byte) blocks
Cylinders
Partition Status Type Start End Length %
1 DOS-BIG 0 370 371 20
2 Active SOLARIS 370 1851 1482 80
SELECT ONE OF THE FOLLOWING:
1. Create a partition
2. Change Active (Boot from) partition
3. Delete a partition
4. Exit (Update disk configuration and exit)
5. Cancel (Exit without updating disk configuration)
Enter Selection:
The following table describes the fdisk menu items.
Table 35–3 x86: Descriptions for fdisk Menu Items|
Menu Item |
Description |
Create a partition |
Creates an fdisk partition. You must create a separate partition for each operating environment such as Solaris or DOS. There is a maximum of 4 partitions per disk. You are prompted for the size of the fdisk partition as a percentage of the disk. |
Change Active partition |
Lets you specify the partition to be used for booting. This menu item identifies where the first stage boot program looks for the second stage boot program. |
Delete a partition |
Deletes a previously created partition. This command destroys all the data in the partition. |
Exit |
Writes a new version of the partition table and exits the fdisk menu. |
Cancel |
Exits the fdisk menu without modifying the partition table. |
