System Administration Guide: Basic Administration
Example—Mounting a CacheFS File System (/etc/vfstab)
The following example shows the /etc/vfstab entry for the /data/abc directory from remote system starbug that is mounted in the cached directory, /opt/cache.
#device           device             mount      FS     fsck  mount   mount
#to mount         to fsck            point      type   pass  at boot options
starbug:/data/abc /local/abc         /opt/cache cachefs 7    yes     local-access,bg,
nosuid,demandconst,backfstype=nfs,cachedir=/opt/cache
