The superblock stores much of the information about the file system, which includes the following:
Size and status of the file system
Label, which includes file system name and volume name
Size of the file system logical block
Date and time of the last update
Cylinder group size
Number of data blocks in a cylinder group
Summary data block
File system state
Path name of the last mount point
The superblock is located at the beginning of the disk slice, and is replicated in each cylinder group. Because the superblock contains critical data, multiple superblocks are made when the file system is created. Each superblock replica is offset by a different amount from the beginning of its cylinder group. For multiple-platter disk drives, the offsets are calculated so that a superblock appears on each platter of the drive. That way, if the first platter is lost, an alternate superblock can always be retrieved. Except for the leading blocks in the first cylinder group, the leading blocks that are created by the offsets are used for data storage.
A summary information block is kept within the superblock. The summary information block is not replicated, but is grouped with the primary superblock, usually in cylinder group 0. The summary block records changes that take place as the file system is used. In addition, the summary block lists the number of inodes, directories, fragments, and storage blocks within the file system.
