System Administration Guide: Basic Administration
Examples—Unmounting a File System
The following example shows how to unmount a local home file system.
# umount /export/home
The following example shows how to unmount the file system on slice 7.
# umount /dev/dsk/c0t0d0s7
The following example shows how to forcibly unmount the /export file system.
# umount -f /export
The following example shows how to unmount all file systems in the /etc/vfstab file, except for the root (/), /proc, /var, and /usr file systems.
# umountall
All file systems are unmounted, except for those file systems that are busy.
