System Administration Guide: Basic Administration
Examples—Adding an Entry to the /etc/vfstab File
The following example shows how to mount the disk slice /dev/dsk/c0t3d0s7 as a UFS file system to the mount point directory /files1. The raw character device /dev/rdsk/c0t3d0s7 is specified as the device to fsck. The fsck pass value of 2 means that the file system will be checked, but not sequentially.
#device           device             mount    FS       fsck   mount    mount
#to mount         to fsck            point    type     pass   at boot  options
/dev/dsk/c0t3d0s7 /dev/rdsk/c0t3d0s7 /files1  ufs      2      yes       -
The following example shows how to mount the /export/man directory from the system pluto as an NFS file system on mount point /usr/man. A device to fsck nor a fsck pass is specified because it's an NFS file system. In this example, mount options are ro (read-only) and soft.
pluto:/export/man   -                /usr/man nfs      -      yes       ro,soft
The following example shows how to mount the root (/) file system on a loopback mount point, /tmp/newroot. LOFS file systems must always be mounted after the file systems that are in the LOFS file system.
/                   -                /tmp/newroot lofs -      yes       -
