System Administration Guide: Basic Administration
IA: Menus Displayed During the Boot Phase
During this phase, you can determine the way in which the system is booted.
IA: Boot Solaris Menu
The Boot Solaris menu allows you to select the device from which to boot the Solaris release. You can also perform optional tasks, such as viewing and editing autoboot and property settings. Once you select a boot device and you choose Continue, the Solaris kernel begins to boot.
Boot Solaris
Select one of the identified devices to boot the Solaris kernel and
choose Continue.
To perform optional features, such as modifying the autoboot and property
settings, choose Boot Tasks.
An asterisk (*) indicates the current default boot device.
> To make a selection use the arrow keys, and press Enter to mark it [X].
[X]  DISK: (*) Target 0:QUANTUM  FIREBALL1280A
on Bus Mastering IDE controller on Board PCI at Dev 7, Func 1
[ ]  DISK: Target 1:ST5660A
[ ]  DISK: Target 0:Maxtor 9 0680D4
[ ]  CD  : Target 1:TOSHIBA  CD-ROM XM-5602B  1546
F2_Continue   F3_Back   F4_Boot Tasks   F6_Help
IA: Current Boot Parameters Menu
This menu appears each time you boot the Solaris release from the local disk. Let the five-second timeout elapse if you want to boot the default Solaris kernel. If you want to boot with different options, select an appropriate option before the time-out period elapses.
                     <<< Current Boot Parameters >>>
Boot path: /pci@0,0/pci-ide@7,1/ide@0/cmdk@0,0:a
Boot args:
Type    b [file-name] [boot-flags] <ENTER>       to boot with options
or      i <ENTER>                                to enter boot interpreter
or      <ENTER>                                  to boot with defaults
                     <<< timeout in 5 seconds >>>
Select (b)oot or (i)nterpreter:
