System Administration Guide: Basic Administration
Example—Checking the File Attributes of Installed Software Packages
The following example shows how to check the file attributes of a package.
# pkgchk -a SUNWbash
If no errors occur, the system prompt is returned. Otherwise, the pkgck command reports the error.
