System Administration Guide: Basic Administration
Example—Site Initialization File
The following shows an example site initialization file in which a user can choose a particular version of an application.
# @(#)site.login
main:
echo "Application Environment Selection"
echo ""
echo "1. Application, Version 1"
echo "2. Application, Version 2"
echo ""
echo -n "Type 1 or 2 and press Return to set your
application environment: "
set choice = $<
if ( $choice !~ [1-2] ) then
goto main
endif
switch ($choice)
case "1":
setenv APPHOME /opt/app-v.1
breaksw
case "2":
setenv APPHOME /opt/app-v.2
endsw
This site initialization file could be referenced in a user's .cshrc file (C shell users only) with the following line:
source /net/server2/site-init-files/site.login
In this line, the site initialization file is named site.login and is located on a server named server2. This line also assumes that the automounter is running on the user's system.
