# sacadm -l -p mbmon PMTAG PMTYPE FLGS RCNT STATUS COMMAND mbmon ttymon - 0 STARTING /usr/lib/saf/ttymon #TTY Ports a & b |
PMTAG mbmon |
Identifies the port monitor name, mbmon. |
PMTYPE ttymon |
Identifies the port monitor type, ttymon. |
FLGS - |
Indicates whether the following two flags are set: d, do not enable the new port monitor, or x, do not start the new port monitor. No flags are set in this example. |
RCNT 0 |
Indicates the return count value. A return count of 0 indicates that the port monitor is not to be restarted if it fails. |
STATUS STARTING |
Indicates the current status of the port monitor. |
COMMAND /usr/lib/saf ... |
Identifies the command used to start the port monitor. |
#TTY Ports a & b |
Identifies any comment used to describe the port monitor. |
