The /etc/saf/_sactab is as follows:
# VERSION=1 zsmon:ttymon::0:/usr/lib/saf/ttymon # |
# VERSION=1 |
Indicates the Service Access Facility version number. |
zsmon |
Is the name of the port monitor. |
ttymon |
Is the type of port monitor. |
Indicates whether the following two flags are set: d, do not enable the port monitor x, do not start the port monitor. No flags are set in this example. |
0 |
Indicates the return code value. A return count of 0 indicates that the port monitor is not be restarted if the port monitor fails. |
/usr/lib/saf/ttymon |
Indicates the port monitor pathname. |
