Adding printer information to a name service makes access to printers available to all systems on the network and generally makes printer administration easier because all the information about printers is centralized.
Name Service Configuration |
Actions to Centralize Printer Information |
Use a name service |
Adding the printer to the LDAP, NIS, NIS+, or NIS+ (xfn) database makes the printer available to all systems on the network. |
Don't use a name service |
Adding the printer adds the printer information to the printer server's configuration files only. Print clients will not know about the printer automatically. You will have to add the printer information to every print client that needs to use the printer. |
The following table describes the major printer-related tasks and the tools available to perform the printing tasks.
Table 2–1 Solaris Printing Component Features|
Component |
Availability |
Graphical User Interface? |
Configures Network Printers? |
Manages Print Clients and Servers? |
Uses LDAP, NIS, NIS+, or NIS+ (xfn)? |
Solaris Print Manager |
Solaris 9 and compatible versions and Solaris Easy Access Server 3.0 |
Yes |
Yes |
Yes |
Yes |
Admintool |
Solaris 9 and compatible versions |
Yes |
No |
Yes |
No |
LP commands |
No |
Yes |
Yes |
Yes |
After using the preceding table to determine which printing tool is best for your network environment, see Chapter 4, Setting Up Printers (Tasks) for printer setup information.
Most printing configuration tasks can be accomplished with Solaris Print Manager. However, if you to needs write interface scripts or adding your own filters, you need to use the LP print service commands. These commands underlie Solaris Print Manager. Performing printing administration tasks with LP commands are described in Chapter 5, Administering Printers (Tasks).
