System Administration Guide: Advanced Administration
Spooling Directories
Files queued for printing are stored in the /var/spool/lp directory until they are printed, which might be only seconds. The following table shows the contents of the /var/spool/lp directory.
Table 8–6 Contents of the /var/spool/lp Directory
File
Type
Description
SCHEDLOCK
File
Lock file for the scheduler. Check for this file if the scheduler terminates and will not restart.
admins
Directory
Link to /etc/lp.
bin
Directory
Link to /usr/lib/lp/bin.
logs
Link
Link to ../lp/logs where completed print requests are logged.
model
Link
Link to /usr/lib/lp/model.
requests
Directory
Directory that contains subdirectories for each configured printer where print requests are logged until printed. Users cannot access this log.
system
Directory
A print status file for the system.
temp
Link
Link to /var/spool/lp/tmp/hostname, which contains the spooled requests.
tmp
Directory
Directory for each configured printer where print requests are logged until printed. Changes to existing print requests are also recorded in this log.
