System Administration Guide: Advanced Administration
Daily Report
This report gives information about each terminal line used. The following is a sample Daily Report.
Oct 16 02:30 2001  DAILY REPORT FOR venus Page 1
from Mon Oct 15 02:30:02 2001
to   Tue Oct 16 02:30:01 2001
1       runacct
1       acctcon
TOTAL DURATION IS 1440 MINUTES
LINE         MINUTES  PERCENT  # SESS  # ON  # OFF
console      868      60       1       1     2
TOTALS       868      --       1       1     2
The from and to lines specify the time period reflected in the report. This time period covers the time the last Daily Report was generated to the time the current Daily Report was generated. Then, comes a log of system reboots, shutdowns, power failure recoveries, and any other record dumped into the /var/adm/wtmpx file by the acctwtmp program. For more information, see acct(1M).
The second part of the report is a breakdown of terminal line utilization. The TOTAL DURATION tells how long the system was in multiuser mode (accessible through the terminal lines). The following table describes the data provided in the Daily Report.
Table 20–3 Daily Report Data
Column
Description
LINE
The terminal line or access port.
MINUTES
The total number of minutes that the line was in use during the accounting period.
PERCENT
The TOTAL DURATION divided by the total number of MINUTES.
# SESS
The number of times this line or port was accessed for a login session.
# ON
Same as SESS. (This column no longer has meaning. Previously, it listed the number of times that a line or port was used to log in a user.)
# OFF
This column reflects the number of times a user logs out and any interrupts that occur on that line. Generally, interrupts occur on a port when ttymon is first invoked after the system is brought to multiuser mode. If the # OFF exceeds the # SESS by a large factor, the multiplexer, modem, or cable is probably going bad, or there is a bad connection somewhere. The most common cause is an unconnected cable dangling from the multiplexer.
During real time, you should monitor the /var/adm/wtmpx file because it is the file from which the connect accounting is derived. If the wtmpx file grows rapidly, execute the following command to see which tty line is the noisiest.
# /usr/lib/acct/acctcon -l file < /var/adm/wtmpx
If interruption is occurring frequently, general system performance will be affected. Additionally, the wtmp file might become corrupted. To correct this problem, see How to Fix a Corrupted wtmpx File.
